Thanks
td27 injectors.
td27 injectors.
Where do I find the numbers on my injectors so I can get the right ones to replace them.
Thanks
Thanks
Re: td27 injectors.
go here i have used this particular spec of terrano as an example,
but select your year and model and it will give you the part numbers to take to where ever to get new one's
illistration at the top, scroll down for part numbers
http://nissan4u.com/parts/terrano/el_wd21/1993_8/type_5/fuel_and_engine_control/fuel_supply_system/illustration_1/
Re: td27 injectors.
is replacing injectors easy
Injectorod
- Driver/Navigator
Re: td27 injectors.
The numbers are on one of the flats of the 19mm hex of the body of each injector ( just under where the leak-off rail sits.) Tricky to see without a light and a mirror. You should see the numbers 0050 and either letter B or T . The letter determines the nozzle number. (I can supply exchange reco injectors )
