over drive light flashing. 1993 surf KZN130, auto
grunta16
Newbie
Newbie
Post by grunta16 »
the over drive light has just started to flash,
the speedo is working fine and it drives normally
it wont go into over drive at all,(normally it was approx 85-90kms,
any thoughts appricated
dsignal
Stropper
Re: over drive light flashing. 1993 surf KZN130, auto
Post by dsignal »
this is because a fault has been detected by the ECU and thus set your truck into limp home mode.
the number of flashes before a pause is the diagnosis code.
mike
Last minute Mike
Post by mike »
Same truck and year as mine and mine has been doing it since 2008, speed sensor on the auto or something someone once told me. My auto just locks up ten k's later (90-95) and thats the only side effect I've had. Kinda annoying towing but thats about it.
If you do fix it, would be keen to one day fix mine.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
The WEHI
Post by The WEHI »
Hope these help you guys out.
Cheers jordan
P.s if you have more then 1 code i recommend writing them down
clearing the fault codes and drive till they return.
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
