New Member with a Surf In Christchurch
evilsurf
Post by evilsurf »
Just recently got a 2.4 Turbo surf ( yeah i no not that great ) it so far has the front torsion bar wound up 50mm and the back has 50mm higher springs. I'm looking to get a snorkel for it and also some real shocks for it what ones are the best for a surf? Also im thinking of putting some 33s on it as well will just a 50mm spring lift be enuf to fit these on ? Also if anyone has a snorkel or some shocks for sale let me know . Also will be looking for some 33s as well if anyone has some going at a good price.
zukmeista
Re: New Member with a Surf
Post by zukmeista »
Would be a good idea to fit a big bore exhaust to help the heat escape, stops head cracking. Here is some info on fitting 33's.
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=22&t=34343
evilsurf
Re: New Member with a Surf In Christchurch
Post by evilsurf »
ok awesome just had a look under the truck and had a measure the exhaust pipe is 2inchs not sure if that is factory or not but it dose go into the last muffler then changes to 1.5 inch.
zukmeista
Post by zukmeista »
2.5" would be a good upgrade, straight through with no muffler if you don't mind a bit of noise.
evilsurf
Post by evilsurf »
ok awesome will have a look around in the new year for a price on that. i was looking online for some shocks are the iron man ones any good? and do you want foam or gas ?
