ozrunner wrote:Actually how are these vacuum hubs setup to get vacuum. Do you run a hose from the engine itself or a tank and do they use a hose via the wheel assembly etc ?
What are the main issues with them, ie do the disengage etc.
Issues? needs a good seal as inner seal on hub. they will engage at normal raod speeds quite happily, NOT 200KPH though!1 (truck cant pull that, but you get the idea) Better I think for dry conditions than for us playing in the swamp all the time!!!
Vacuum. Petrol engine, right? OK, use the vac line that feeds the power brake booster, run a line to a electric vac breaker to control vac. tie THAT operation into the 4wd selector so wen u select 4wd either hi or low, it engages . works ok on Ssangyong like that.
need to drill a hole into the hub that lands INSIDE the inner oil seal, vac is then drawn thrugh the hub for operation.
I was thinking of using auto hubs but most seem to disengage upon reversing which would be a bitch in some tricky situations.
The electric hubs would be the go but there is the issue that they really aren't made for the IFS Toyota so it will require some work to fit them, if at all possible
Spline count? Photo? no worries. rushing out to garage to do just that.... dont go away..... BRB.....
ahhhh here I am, back, didnt take long eh? ... quick wipe to clear some of the grease and shit....
forgive me for doing sizes in imp measurements, but I think in Thousandths of an inch, not bloody millimetres
OK, 28 count spline
Shaft dia AT SPLINE 1.15 inches
shaft dia behind spline 1.18 invhes
PCD of mounting holes 1.650 inches 83 MM
mounting hole dia 0.40 inches
go to...
http://www.avm.com.br/products.htm for more info.
