rear axcel bearing replace on my old 1991 terreno HOW
is this an easy job rr bearings gone is this an easy job if I get the wheel hub offdo I just undo remove caliper then undo the 4 bolts does it then just pull out
- jonossiksilvia
Re: rear axcel bearing replace on my old 1991 terreno HOW
Yup most rear axles come out like that. Dont forget to drain oil first so u dont get it rushing out when pulling axle. Thats all the easy part. Getting the bearing race off is the tricky part
This may help:
http://terranoirk.ru/man/R20/ra.pdf
This may help:
Or you can jack the one side up high and you dont need to drain the oil.
- jonossiksilvia
ChurchurDan wrote:Or you can jack the one side up high and you dont need to drain the oil.
If its not fairly new oil, id just do it for the sake of $40 for fresh oil
Yeah but I always make a big mess getting the new oil in. And im a tight arse.
