is there any factory ute body mounts taller than others between models?
looking to remove a mates body lift and replace with a factory set.
he has a d22 double cab but im sure mounts from a d21 or terrano or Datsun would suffice to avoid the cert man
Factory body mount heights
Re: Factory body mount heights
any change to the original body mount height requires a cert. just because the wof man doesn't see it, doesn't make it legal.
Tony.
ChurchurDan
As far as I know all the mounts are very similar. The height difference between models is in the chassis. The utes have higher mounts than terrano's, so you already have the highest factory mount.
not changing the mounts at all just looking to put new rubbers and crush tubes in, his are 30mm from the chassis to the cup,
they look to have been given a hard time so the cab rattles bit hence replacement
