A350E auto trans into challenge truck TCU help
NOBDY
Post by NOBDY »
We are hopefully putting a A350E auto transmission into the challenge truck.
This gearbox is used in lexus 300GS in 98 and has appeared in a few other overseas models of different cars – Volvo and 4runners (2wd ones I think) supra, and fj cruisers 2007-2011)maybe these are 2wd overseas? I don’t know.
It is made from a Toyota A340A (4 speed) but has had some messing around manly (only?) with reprogramming, so that when in second, overdrive is also activated, giving an extra gear (new third gear ratio).
The gear box is normally controlled by the car ECU, but we are ditching that for a link, running a 3UZ-fe (that’s a 4.3ltr lexus V8 in English :D )
I’d like to try to find a standalone Transmission Control Computer that will run this gearbox.
Because they were only made for one year in Toyota production cars, they haven’t been played with very much. Some criticism of the gearbox is out there to, things like unreliable due to extra electrics (has 6 solenoids) and concerns about the overdrive also working when in second gear, when it was designed originally for highway cruising).
I don’t want other gearbox suggestions, as we have access to a bunch of these box’s and want the close ratios.( I could be back in a month though looking for other ideas……. :cry: )
Would like normal auto mode (cus I’m dumb), and triptronic (so I can play) :lol:
During research, I discover that wholesale automatics in Aussie are making a standalone TCU for a A750E, in about 2 months, if anybody is interested in that.
TCU’s I’ve looked at are
TCS from the states – they say they can do a A650E, but can’t find out about a A350E, awaiting a reply on that from them at the moment.
MegaShift, think it’s an offshoot from Megasquirt, it’s a TCU which is meant to be fully programmable also, but can find very little info about these either – has anybody delt much with Megashift or Megasquirt? There is a guy in Chch? Who deals in Meagasquirt I think, can anyone hook me up with his details please.
Also around is supra shift, but again not sure about controlling this box, as it’s quite different to standard.
Black Ridge customs also make one called TSM-2000, which is another option.
Last option might be re-programme a link to run the tranny. Has anyone tried this?
Lastly, am I missing the point somewhere here? :? Is there an easier way (keeping this box though)
I have the wiring diagrams and parts list/numbers, but still need the map of what solenoids are on/off per each gear, any help on finding that would be real handy to, if we are going to re-programme something…..
Big
Re: A350E auto trans into challenge truck TCU help
Post by Big »
Link cannot control the trans
Supra stick do a full auto controller and manual controller option from the same ecu at the flick of the switch.
You could manualise the auto with 2 relays.. works very well but if a daily driver not a good option.. For a winch truck then perfect.
The A750 trans are weak as piss so stay away.. only good for about 350-400 hp then fly to bits..
Otherwise if you do manage to come across an inexpensive controller the please share.. :wink:
Mattman
Post by Mattman »
I will see if I can find the link for an arduino based TCU. A Swedish guy running big boost in diesel mercs made his own fully programmable controller.
The theory is quite similar across all trans so you should be able to adapt something.
Edit: Here is the link
http://www.superturbodiesel.com/std/Thr ... 22-6-ver-2
Matt.
wjw
Post by wjw »
You can use a Jeep TC on the A340's, the one I used for my A343F was from an XJ
Who knew Prados could fly?
kbushnz
Post by kbushnz »
I manualised my A340...link is http://www.offroadexpress.co.nz/Forums/ ... 17&t=29063
Also looked at lots of controllers... and think the Suprastick was the best for options and value for money
http://www.latentsolutions.com/suprastick.html
Go fully auto with your own shift points...
And also go tip tronic....
