Drum Brakes self over adjusting
brakes-shocks-lockers-etc
dutchy
Post by dutchy »
Hi guys.
done a bit of research and didnt get to much joy.
my left rear drum brake on a kzn130 hilux surf is over adjusting.
I de adjust it so that it is almost free spinning (other side is adjusted correctly and stays to a good adjustment)
takes about 2 days and there is a very noticeable drag so I de adjust again. (VERY hard to turn to the wheel before I de adjust it)
does anyone know a solution?
chris
Surf - 50mm lift, front bar, integrated winch etc
contactable on 0220901730
tweake
Re: Drum Brakes self over adjusting
Post by tweake »
check the hand brake cable. it may be to tight on that side and possibly not fully retracting.
mudlva
Post by mudlva »
Strip the drum off and check that the adjuster tab is correctly aligned and also not worn or broken
dutchy
Post by dutchy »
cheers, I Will have a look at both suggested issues.
also should note, it was working perfect until i slightly adjusted the adjustment wheel (on both sides) and thats when it started.
churchill
Post by churchill »
Check for sticking slave cylinder.
Mattman
Post by Mattman »
Do the disk conversion now and save yourself the time and money :-)
Drums will always give you grief if you off road in mud and water.
Matt.
dutchy
Post by dutchy »
taking the drum apart tomorrow, will post results.
Mattman wrote:Do the disk conversion now and save yourself the time and money :-)
Matt.
big words there, build threads for kzn130 and useful links please
Mattman
Post by Mattman »
I did a conversion on my LN130 with a set of brackets made by Deranged with a pair of MR2 calipers and modified Prado rotors.
If you search on here you should find plenty of info. Straight forward conversion but needed certing.
Matt.
dutchy
Post by dutchy »
churchill wrote:Check for sticking slave cylinder.
you were on the money! 8) one side of the cylinder was siezed and leaking.
Thanks everyone for the help.
churchill
Post by churchill »
Nice, that should be a cheap fix too.
dutchy
Post by dutchy »
churchill wrote:Nice, that should be a cheap fix too.
yeah did the shoes and cylinders on both sides for $100.
the next few days will tell if that really was the issue.
