spring over axle conversion
I have a bj73 cruiser that I want to do a spring over conversion on. I s there a kit that can be purchased? I am just a dodgy builder so will need to get it done by someone and am trying to keep the cost down.
- niblik
- Sausage Shack
soa huh?... good stuff...
i'm doin same to my 40..
no 'kit' that i know of..
but..
use ya std springs, cut off and reweld new spring perches on diff housings, new locator pins in spring packs, cut and turn on front housing and possibly elongate the driveshafts ( may get away without having too..), hi-steering setup, possibly new spring plates too..
http://www.ih8mud.com/tech/soa/index.html
try reading the link above.. its not too bad to perform yaself and the difference between doin it to a 40 and 70 is damn near the exact same..
hope i've been a little help..?
good luck!
but..
good luck!
- niblik
- Sausage Shack
theres also heaps of other write ups on soa's and other mods etc..
have a read at your leisure..
http://www.ih8mud.com/cruisertech.php
make sure you take pics and stuffs huh? cool..
;-p
another passing to the dark side, where the force is much stronger
......no really it is, you will need to put diff braces on as well
plenty of pics of doing SOA in mine and nibbys photo album, except his are spaced out for the extra width of 60 series housings.
front perch
diff brace
[img]front brace back to chassis
http://www.offroadexpress.co.nz/images/ ... .sized.jpg[/img]
thats all i have to say about that.....
front perch
diff brace
