Hi all,
Up for sale is my 1992 Hilux doublecab
The Good
Solid 3L engine and box, No crunches
TJM styled bullbar with steel centre, with a Thompson winch (Unsure if it works)
Electric front windows
Full sized mirrors
Crystal lense headlights
Blue ice headlight bulbs
Recaro front door cards
Newer dash from KZN185/167 with blue fading to black speedo dials (Need to adjust temp gauge and fuel gauge needles, have not yet connected tacho or glow plug light)
Front and rear diff breathers (Included is gearbox and transfer case breathers but not installed yet)
WRX front seats included, currently has surf front seats
UHF Radio (maybe)
Resprayed white (Originally white but was looking shabby, respray not great but comes with 4 litres of High gloss white paint)
Chrome hilux rollbar
Tonneau cover
Tuffdek
Solid front axle
Fresh rear diff oil
LSD Rear diff
Rebuilt front right steering knuckle
New right rear wheel bearing and axle seals
New battery 6 months ago
Fresh WOF, reg and RUC in credit
Included is a set of TrailGear front brake rotors from Suzolla which allow VZN130 surf front callipers to be fitted
Also included is front and rear extended braided brake lines from suzolla
The bad
Needs new glow plug timer (might get around to that)
Bit rough around the edges
I also have 2 rebuilt diffs with 5.29 diff gears that could be included depending on price, these have spring perches from a landrover fitted to them but could be fitted with hilux gear again fairly easily
Could also include a set of 33 inch BFG All terrain tires on 16 inch rims again depends on price
92 Hilux Double cab
uptomynutsinruts
uptomynutsinruts
Re: 92 Hilux Double cab
http://www.offroadexpress.co.nz/Forums/ ... 22&t=36925
photos and details here too
uptomynutsinruts
