Diff drain plug stuck...
Marco Polo
My diff drain plug on my L200 is stuck hard... I have finally resorted to my 600NM Bluepoint rattle gun and it still won't move, in fact it rounded the bolt head!!
Any suggestions?
Any suggestions?
How hard can it be?
Re: Diff drain plug stuck...
weld a nut to it, the heat will free it and you can use the nut to unwind it
Marco Polo
Good idea, seen that trick used before, but I don't have a welder. What about a blowtorch on the plug and bash the impact socket back on and have another go?
How hard can it be?
Use a hand file to straighten the edges to fit the next size down socket on the plug. Will take a while but you can tidy it up. Also try and use a 6 point socket.
Matt.
Matt.
Hit it with a hammer. The jarring will help loosen it. Don't use crappy tools on it, or you'll make it worse for yourself. Maybe even take it to a garage to get them to do it? $15 might save you two hours+ of headaches
had this with a stuck wheel bearing plate star screw, used a bit of shock to the head, 1/2 a can of crc and tightening/loosening it repeatley.
Make sure you use 6 point heavy wall sockets when wrenching hard on nuts.
excuse the pun.
I managed to get mine out with a 1000mm breaker bar and a trolley jack underneath it holding the socket hard up.
Beware of the old knuckle bash when it lets go though.
Marco Polo
Colinl wrote:Make sure you use 6 point heavy wall sockets when wrenching hard on nuts.excuse the pun.
too true!!
I have a 6 point impact socket I have been using. I might get angry on it on the weekend with some heat.
How hard can it be?
Before I remove my diff drain plugs I make sure that I can get the filler plug out. I assume you have already done that
Marco Polo
nzlux wrote:Before I remove my diff drain plugs I make sure that I can get the filler plug out. I assume you have already done that
Oh yes, I learnt that a long time ago! Fill plug came out easy as.
How hard can it be?
Then replace it with a new plug that you can buy from Toyota that is tightened with an 10mm Hex Allen Key. Let me know if you want the part number.
I did wonder why my new truck had those on it oldblue
Diff/Transfer/ Gearbox, Fill or Drain Plugs ( Hex type ), Toyota # 90341-18021
oldblue wrote:Diff/Transfer/ Gearbox, Fill or Drain Plugs ( Hex type ), Toyota # 90341-18021
use steel washer for diffs & alloy washer for gear box & xfer case
Gardengnome
- Truck Hore
