Hi Guys,
I have a bunch of Lock Right Lockers left over, so am going to do a deal for members:
PT 1510 - Suzuki Samurai - $450 (RRP $500)
PT 1512 - Escudo/ Vitara - $450 (RRP $550)
PT 1610 - Toyota Hilux 8" 2 Pinion - 30 Spline - Solid Axle - $575 (RRP $700)
PT 1611 - Toyota Hilux 7.5" 2 Pinion - 27 Spline - IFS - $575 (RRP $700)
PT 1620 - Toyota Hilux 8" 4 Pinion - 30 Spline - V6 - $575 (RRP $700)
PT 1622 - Toyota Hilux 8" 4 Pinion - 30 Spline - To fit Factory LSD diff - $575 (RRP $700)
PT 1630 - Toyota Landcruiser 9.5" 12 bolt - 30 spline - $575 (RRP $750)
PT 3210 - Nissan Safari/Patrol - 31 Spline - FRONT - $575 (RRP $700)
PT 3220 - Nissan Safari/Patrol - 31 spline - REAR - $575 (RRP $700)
Let me know if your interested
Caleb
Clearance - Lockright lockers
Moderator: Vendors
027 MUD GEAR - (027 683 4327)
Check our facebook:
Re: Clearance - Lockright lockers
Filthy4x4 wrote:PT 3220 - Nissan Safari/Patrol - 31 spline - REAR - $575 (RRP $700)
33 spline rear unless you are referring to the older MQ/MK model
left over
Yeah you not seen that cupboard before ?
Check our facebook:
