L200 4D56 thermostat question
Marco Polo
Post by Marco Polo »
Hi Mitsi experts....
I decided to replace the thermostat in my L200 and the replacement looks nothing like what came out. Now, given the history of this vehicle this does not surprise me. Can anyone tell me if the proper thermostat has a rubber ring around it and no gasket, a rubber ring and gasket or just a gasket?
I have a 4D56 manual and the exploded diagram shows just a rubber ring.
Partmaster gave me a thermostat and gasket but no rubber ring. I installed it with no rubber ring, with the gasket and it leaks....HELP
How hard can it be?
zukmeista
Re: L200 4D56 thermostat question
Post by zukmeista »
The ones that have a rubber ring around the outside don't usually have a gasket, I would use the ring with a bit of gasket goo on the housing to be sure.
cornflake
Post by cornflake »
just did the same i just used gaskit goo makes it easyer mine came with a gaskit didnt even fit so just used the gaskit goo stuff no leeks at all
wildplumdx
Post by wildplumdx »
L200 and Pajeros have different waterpump thermostat housing set up and the pajero ones have a rubber ring around the thermostat L200 ones don't that i have ever come across mine have never had one. and ditto i never use paper gaskets just goo the sucker
Marco Polo
Tridon lists the same part for Pajero and L200 turbo. The tridon thermostat will not seat correctly in the housing and the guys at Partmaster had had this problem on several previous occasions with 4d56 applications. They gave me my money back and advised me to go genuine. So I order a genuine Mitsi one $68+gst trade!!! Then I got a call back from Partmaster saying the suppliers of another brand called back with a suggestion to use a different part number that is usually listed for Nissan primeras and various Mazdas
And hey presto, a perfect fit! I used the gasket and it seals just fine.
How hard can it be?
Return to “Mitsubishi”
