LJ71 Landcruiser( Bundera) Rear Shock Absorber
cruiser71
Stropper
Post by cruiser71 »
Hi I am new to 4wd thing but I have just bought a 1988 landcruiser.I am looking to replace rear shocks as one was stuffed when 1 bought it.Thinking of doing both at the same time but they both are different to each other. i.e one has top and bottom eye and 1 has top stud and bottom eye.Vehicle has 50mm lift so if someone can tell me what Shock extended length and shock collapsed length will do the job.
Where can I get these as a pair in nz.
slide
Re: LJ71 Landcruiser( Bundera) Rear Shock Absorber
Post by slide »
Whereabouts are you located?
The LJ71 rear shocks I have are both the same, eye top and threaded pin (stud) at lower end. They're from a 1992 model, could be different to your '88
redz driver
Post by redz driver »
Where abouts are you mate
Real men drive swb leaf spring trucks
cruiser71
Stropper
Post by cruiser71 »
I am In Ashburton
kbushnz
Post by kbushnz »
The bundera has different shocks on each side of the rear. Old man emu do a set of shocks. Std and lifted.
Trundle
Post by Trundle »
Im pretty sure i have some Amadas for the model with different rears , if you are after some they are $560 a set of 4 inc gst , 46mm bore 20mm shaft and come with dust boots etc ,
