Finally removed all the IFS bits from the front of Project Surf-O-Dore
Was going to put the rear springs in the front but not sure that they will give the flex that I want, plus hard to maintain a good approach angle while giving good flex.
Have decided to use 3 links arms and a panard.
Engine will be a V6 Commodore
Question is, what springs are people using in their coil fronts that gives them plenty of flex, what is the free length and how much do they compress. Do you know what the spring rate is.
Do you have any pictures of setup and how much flex do you get.
Thanks in advance for any comments.
Tim
Surf LN61 Coil Front Suspension Questions
Coils will out flex leafs by a million miles, if they are done correctly. Setting coils up is a lot harder, beacuse if they don't work the way you want, you have to get some more and keep trying until you get the result you are after. With leafs, you can mix and match different leafs to create a wicked spring pack, however, I have never seen an "off the shelf" leaf spring pack work to a degree that I would call impressive.
