Hi,
Have got some rubber suspension bushes that fit the front of Safari leading arms. These are actually genuine Toyota rubber suspension bushes that fit..
Axle end of the front leading arm
Part no. 48702-60050
4 are required for a complete set.
Dimensions are ID 16mm, Length 50mm, OD 60mm, Length 40mm
$55 each incl post
PM me if interested.
Tim
Nissan Safari Leading Arm Axle End Bushes
Moderator: Vendors
Re: Nissan Safari Leading Arm Axle End Bushes
Cheers everyone for your input I will start checking/ replacing anything that looks semi dodgy and go from there...
As for tire pressure I find it drives nice at 45psi and there is no uneven wear happening at all but I will have a play around with pressures and see if it makes any difference.
If you cant beat us Gingers, JOIN US!!
