Looking for $500.
I put this on my Hilux for a few months then took it off when I sold up and went to the dark side (Nissan). Was never used, rope still wound perfectly on the drum from factory
I have all the bits - wireless remote, wired remote, mounting bolts etc. didnt use all of the supplied cable as I put the solenoid under the bonnet so not 100% sure if all the cables are there but a few longer pieces for you to use if needed. I can help out if you need different lengths of cable made for it.
Unfortunately this wont work with the Safari/Whale as its heavy and 24v, so might be keen on a swap for a 24v 12000lb winch
