WANTED: Toyota hilux gear box
So how it goes is my mate needs it, just been told by his mechanic it needs a new one so anyone got anything lying around that would slot straight in? its an Ln65 double cab with a 2l-t engine. He is a carpenter if someone needs services in return haha located in timaru
Re: WANTED: Toyota hilux gear box
So you are looking for a G52 box to replace what is already in there, or you can bolt a W56 in there also, just need to move the hole in the trans tunnel about 20mm to let the gear-levers work. W56 also takes a different transfer to the G52 so bear that in mind. W56 is meant to be a bit stronger too.
I've got a g52 in rangiora
there's 2 buried in the paddock been there a while though
