92 Terrano Annoying Dash Squeak
For all Nissan related topics
stovanovich
Post by stovanovich »
Over the weekend the truck acquired an annoying noise coming from around passenger side dash when driving along the road :x Best described like a rattling squeak, any terrano owners got any ideas. For the life of me cannot figure it out and starting to do my head in.
Te Rino
"Hubs In, Caps Off"
Crash bandicoot
Re: 92 Terrano Annoying Dash Squeak
Post by Crash bandicoot »
stovanovich wrote:Over the weekend the truck acquired an annoying noise coming from around passenger side dash when driving along the road :x Best described like a rattling squeak, any terrano owners got any ideas. For the life of me cannot figure it out and starting to do my head in.
plastic on plastic check the PK screws that hold the glove box in place.
Cambo
Post by Cambo »
Had mysterious squeak in mine from the left hand side for ages, I was adamant it was the dash but turned out to be a loose screw on the LF speaker, only took around 8 months to find it!
travis2ninja
Post by travis2ninja »
I have an annoying plastic squeaking noise also, been there a few months now.
Sounds like its coming from underneath the dash around the top behind the speedo.
It only stops when you push really hard above the dash.
I have pulled everything out i can, but i cannot get up any higher because of the black plastic for the air con.
Any ideas?
poss682
Post by poss682 »
I have this too..... :cry: :lol:
stovanovich
Thanks for the tips thus far, will check those to help eliminate some possibilities, otherwise this here is a quick vid of the noise if it helps diagnose
http://s1360.photobucket.com/user/stova ... d.mp4.html
Te Rino
"Hubs In, Caps Off"
Bompie
Post by Bompie »
I chased a squeak in my dash for ages I had had the glove box out but couldn't find anything in there, also tried taking the panel off below the wipers but no noise there either and found it was actually the the plastic seals on the bonnet hinges rubbing against the fire wall. theres usally a little foam on these plastic bits but it had worn away and was rubbing plastic on steel. sprayed abit of grease on and noise went away straight away. hope this helps.
Nissan Terrano stock standard kind of.
