Wanting to fit a dinger or a buzzer to the temp warning side of the automatic.
Can I just tap into the warning light loom that go's to the Auto heat warning light which is just in front of the shifter.
Any advice welcome.
Fitting Warning Buzzer to Auto
Aaron wrote:
I think if you just tap it in after the light you should be fine![]()
the small buzzers that some jap vehicles use for speed warnings work well they are small and dont need to much current to make them work.
It they do need more get a decent relay...
Who knew Prados could fly?
