Had my fan inside the cab stop running. Was running when I drove home from work one morning and then that evening when I jumped in to go back to work it would not.
I have quickly checked out all the fuses behind the drivers kick pannel and seem fine.
Any pointers to head to next?
Also noticed the rear fan switch on the dash not lighting up when I flick it on and the fan in the back not going?
Kind of need the heater on the Grave Yard Shifts!!
Safari Interior Fan stopped working
- gary_in_nz
Re: Safari Interior Fan stopped working
Not sure if it would affect the rear fan but drop the front fan out of the case and make sure it isn't blocked.
Mine was full of leaves etc, only need to undo 3 screws.
ChurchurDan
check if the fan motor is getting power to it with the key on and getting earthed when the fan switch is turned on. If so your fan motor has died.
- gary_in_nz
sweet cheers, will check out today
