Prado 70 series E locker axles, Question
Is there a difference in the rear axles in 70 series Prado, between the E locker and standard diff.
Re: Prado 70 series E locker axles, Question
And when you put one in the front out of a prado rear are standard hilux front axles fine?. whacked it in without measuring oops.
smurf can measure the axles in prado diff for you my locker came out of if no one comes forward with the answer for you. but ales been bolted back in an empty housing so accuracy be difficult.
Thanks people Clive
Thanks people Clive
Smurf wrote:Is there a difference in the rear axles in 70 series Prado, between the E locker and standard diff.
Ok there is only one difference between the two... And thats the shape of the mounting flange for the diff...
As the e locker axle has a cut out for the locking ring and some studs are in different places...
The drive axles fit just fine so must be the same..
How do I know? Cause I swapped in an E locker into a std axle assy.
Plenty of info about retro fitting an E locker into std axle on the net...
I think he(the OP) may be referring specifically to the axle shafts.
BlakeNZ wrote:I think he(the OP) may be referring specifically to the axle shafts.
Yes, I should have been more exact with my question
Smurf wrote:BlakeNZ wrote:I think he(the OP) may be referring specifically to the axle shafts.
Yes thats what I thought too.... Axle shafts appear the same... Well they fitted fine when I modded mine... That was 7 years ago.
kbushnz wrote:Smurf wrote:BlakeNZ wrote:I think he(the OP) may be referring specifically to the axle shafts.
Good enough for me, Cheers again Calvin
I did a whole rear end swap as I picked one up cheap so unbolted the radius arms and drive shaft and swapped in the whole diff. Over the years i have changed the axle sub assemblies (hub, axle, brake ect) between the locker one and open ones for different reasons. Never noticed any differences or had any issues with it.
axel wrote:I did a whole rear end swap as I picked one up cheap so unbolted the radius arms and drive shaft and swapped in the whole diff. Over the years i have changed the axle sub assemblies (hub, axle, brake ect) between the locker one and open ones for different reasons. Never noticed any differences or had any issues with it.
Cheers for the reply.
