boost tap install. can it let water in deep water crossing?
44jetboat
Post by 44jetboat »
going through putting in a boost tap.
i see they bleed the boost off.
does this cause a issue when crossing bonnet deep water?
or because it is postive pressure (boost) do you not have to worrie about this?
or am i best to run it in the air box.
Mattman
Re: boost tap install. can it let water in deep water crossi
Post by Mattman »
It has a one way valve so you can't suck anything in.
44jetboat
Post by 44jetboat »
great cheers for that.
tweake
Post by tweake »
bleed types don't have a one way valve in them (tho the better ones do). in theory could leak water in. however its going to be a tiny amount. it might be an issue if the engines stopped and its under water.
ball and spring ones are better for diesels anyway.
