Hi guys, just a quickie on what coolant I should use on my 21V VX cruiser and how much I should put in?
Also what oil do you use in the diffs/engine etc?
24V VX cruiser coolant and oil
Ph 0212078472
Ph 0212078472
Re: 24V VX cruiser coolant and oil
Engine
Service Refill Capacity: 9.7* Litres.
Differential
Service Refill Capacity: 2.6 Litres.
4WD Transfer
Service Refill Capacity: 1.3 Litres.
Radiator
Service Refill Capacity: 12.1-13.1 Litres.
from http://www.datateck.com.au/Lube/PenriteAus/
Differential
4WD Transfer
Radiator
Who knew Prados could fly?
I use Gulf Western Top Dog XDO in the engine, Castrol Limited Slip oil in the rear diff, Castrol standard diff oil in the front diff.
sinopec or mobil delvac mx engine oil are good, i have been trialing the HPR diesel engine oil in my bus for the last couple of changes, jury is still out on it so cant comment. i allways add a bottle of moreys heavy duty oil stabiliser when i do an oil and filter at about 8-10k ish or just when its getting a bit black.
as for the diffs redline or castrol diff oils are good.
