AVM manual hub on surf won't disingage.
traversd
Post by traversd »
Hi there,
Manual hub on surf won't disengage. Isn't my vehicle, but I'm trying to replace it for a mate, i have a replacement hub. But I am having trouble removing the old one.
Does anyone have a clue on how to remove the allen key hex bolts that are on AVM manual hubs? once they are fully siezed in, is drilling the only way?
Tried mpact driver and all and they will not move. need to remove and replace hub, hub is stuck between 4wd and2wd
started trying to drill hub out. But no luck.
Any ideas? Cheers
mudlva
Re: AVM manual hub on surf won't disingage.
Post by mudlva »
Dont drill the heads out!!
The shafts are tappered and taking the heads off will not help!!
Cut a allen key so you can fit a spanner over it and tap with a hammer at the same time.
Worse than pulling teeth but the only way that i found that worked
truckingood
Post by truckingood »
once you get them off chuck em, and buy the warn hubs ive got :D
callum007
Post by callum007 »
I managed to hammer a larger torx drive bit in and lets of crc, then freeze spray and they came out then got thrown in bin
Marco Polo
Post by Marco Polo »
As above. They are horrible little fasteners. I also used a sacrificial torx bit to get them off my Isuzu. Once I got em off and dismantled I remember being very unimpressed with how lightly they are made...
How hard can it be?
