As above.
Im after a pair of manual hubs for my Nissan safari as my free wheeling hubs have shat themselves.
0275129266
Wtb Y60 Manuel hubs
Re: Wtb Y60 Manuel hubs
http://www.4wdbits.co.nz/ProductDetails ... uctID=1485
I've found them a good product - running 35in tyres...
Thats what im after.
Did you read the product description:
"The outer casing is a CNC machined ADC12 aluminium alloy die casting making this hub unsuitable for off road use. They are fine for gravel roads, boat ramps and crossing the lawn with standard size tyres and no front diff lock.
NB:These hubs are basically rubbish, they will look the part and be ok on the boat ramp. A cheap replacement not designed for off road use."
Amazing to see such honesty on a retail website. If I were you just would spend a bit more and get something more suitable.
These would be a better option, only $100 more.
http://www.4wdbits.co.nz/ProductDetails ... uctID=4881
marmel wrote:These would be a better option, only $100 more.
Definitely use these ones.
They both look very similar,
I didn't notice the difference at first glance on my first post - it's definitely the ones at $250 / pair that I'm running...
I got these after the cheap ones prev owner had put on failed
http://www.4wdbits.co.nz/ProductDetails ... uctID=4305
these are made very well, and performed well, worth the extra $
