70 series axle shaft
munched splines on front d/s axle shaft on fri nite
. blew cv into about 20 bits, brought new cv's , need s/hand shaft ,anyone help???Goes to show how strong the lockrite lockers are!!
;-p
as far as im aware the short side axles are the same right thru all the cruisers. only the long side is different
i have a spare short side axle if you need one bud. cost you postage.
i imagine theres one closer to you than me tho
70 series cruisers axle width's are suposed to be wider than 40 series? I've got a rear long axle out of a 40 in my 70, I never measured it when I put it in and just assumed it would be the right length
I found these front long axle lengths a while back and it shows pre 1990 long axles as the same length as 40 series, dunno about the short axles?
