putting elockers front/rear in KZN185 surf - parts needed?
brakes-shocks-lockers-etc
floatingkiwi
Post by floatingkiwi »
Hi Folks
I'm putting Eaton/Harrop elockers in my truck, front A11167 and rear A9334, and would like any hints or things to remember from you guys.
Also, should I get new bearings/seal kits from Terrain tamer (or anyone else) for each diff? Are the bearings destroyed when doing the job?
Anything else I should do?
1999 KZN185W SSRG TJM T-15 Bar, Tigerz11 2speed winch, 2" EFS sus lift, 265-75R16 Engine guardian. Auberins EGT. LED light strips. weathertech cargo liner. Safari Snorkle SS145HF. Prado rad. Front and rear E-locker.
Re: putting elockers front/rear in KZN185 surf - parts neede
may as well give it new bearings, it's common to do so when putting a locker in
lax2wlg
Post by lax2wlg »
Yep and solid pinion spacer, get rid of that crush sleeve. Its going to need replacing anyway, may as well upgrade to Solid spacer to avoid the possibility of preload getting slack and ultimately munching your r&p
floatingkiwi
where's the best place to get this stuff from folks?
bearings a bearing shop is a good start or you local toyo dealer maybe
lax2wlg
Post by lax2wlg »
I used yotamasters.com and Trail Gear for Toyo diff stuff when in the US, however Im sure there are local options too. Try suzolla/4wdstuff here on ORE
Clint
Post by Clint »
Not sure on the Surf but I didn't need any extra parts to put the e-locker in my rear 80 series diff. I put in new bearings anyway along with a solid spacer, got a Terrain Tamer kit from Performance Mechanical in Taupo.
Clint
UZJ71 Landcruiser
KTM 640
Trundle
Post by Trundle »
We can do the rebuild kits and E-lockers also if you have not got them yet ,
