transfer case rebuilding ln130
Has anyone got a manuel showing the strip and rebuild of Surf transfer case?
93 service manual for a pickup, but I think transfer will be the sameish.. check the numbers.
http://www.wjw.co.uk/toyota/93fsm/index.html
Transfer case info:
http://www.wjw.co.uk/toyota/93fsm/transfer.html
Transfer case info:
Transfer
Description
Precautions
Troubleshooting
Removal of Transfer
Installation of Transfer
RF1A
Components
Disassembly
Input Gear
Idler Gear
Counter Gear
Output Shaft
Front Drive Gear
Oil Seals
Assembly
VF1A
Components
Disassembly
Oil Pump Body
Driven Sprocket
Rear Output Shaft Assembly
Input Shaft
Planetary Gear
Oil Seals
Assembly
Who knew Prados could fly?
