Trouble mounting mcc winchbar
4x4pirate
Post by 4x4pirate »
Just purchased a mcc winch bar to suite my 1994 toyota Hilux ln106 4x4 having trouble mounting it holes are all out and it's a tight squeeze. Anyone had this problem before ???
mudlva
Re: Trouble mounting mcc winchbar
Post by mudlva »
i know this is a long shot but have you tried talking about this problem with the company that sold the bar??
4x4pirate
Post by 4x4pirate »
Yeah have emailed them waiting on reply now just thought I'd ask on here see if anyone had same problem
J_Dub
Post by J_Dub »
If its purpose made for that model and it don't fit then they need to rectify it.
They might not even know, their moulds and jigs may be out
Crash bandicoot
Post by Crash bandicoot »
then being a ln106 from 94 was it made for the last of the live axle or the first of the IFS chassis?
slidenyo
Post by slidenyo »
mount brackets first loosely to chassis then mount bar to brackets,
jack into position of desired fit,
tighten brackets to chassis then tighten brackets to bar.
mine was tight also when I tried mounting everything on the ground,
the bracketry seemed to be ill fitting until I went about it as advised.
hopefully they have given you the correct bar, was 6 weeks wait for mine
Mehrts
Post by Mehrts »
Crash bandicoot wrote:then being a ln106 from 94 was it made for the last of the live axle or the first of the IFS chassis?
LN106 were always solid fronts up to 1998 which was the change-over year.
LN107 is the IFS SR5 models of the same era.
Toyhatsu Bitsalux
Crash bandicoot
automotive production years don't go by date's for example 31 december 1997. model changes happen usually in august the previous year so auto makers have chance to build up stock for demand.
the IFS cab/chassi hilux(not the surf which was IFS since 89) started production on 95 in some countries and live axle was stopped august 96, any sold after that date were over supply of old stock.
callum007
Post by callum007 »
My Mitsi MCC Bar was the easiest bar Ive fitted. couple hours and few beers and quick lift from the neighbour. simple
tuff lux
Post by tuff lux »
when had one for a ln106 there was no way it was fitting had to attack it with the grinder and welder
4x4pirate
Post by 4x4pirate »
Yeah this one is made for ln106 have double checked going attack with grinder and welder and she be mint as !!
Return to “Tool Shed”
