Hi all,
I am removing a bodylift from my KZN130, however I don't have the factory bolts that hold the body to the chassis. Does anyone have the measurements of them? Cheers
KZN130 factory body/chassis bolts
Re: KZN130 factory body/chassis bolts
Just get high tensile bolts that are 50mm shorter (or whatever height the body lift is) than the ones that have been used for the body lift from any hardware store.
Toyhatsu Bitsalux
I have a set of originals here with out the press on washers. Where about's are you?
