Hi guys,
New here, just have a quick question. Am I able to get a WOF with a tough dog adjustable panhard rod? I only have a 50mm suspension in a KZN130.
Adjustable panhard rod - KZN130
Re: Adjustable panhard rod - KZN130
Yep not a problem as long as it is installed correctly and the bushes aren't flogged out.
Toyhatsu Bitsalux
with 50mm lift you can get away without it.
You need a cert for adjustable suspensions arms unfortunately
^what he said.
Trundle wrote:You need a cert for adjustable suspensions arms unfortunately
Given that, if it was me, I would be very tempted to have an appropriately skilled person just lengthen the current panhard to suit.
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Clint wrote:Trundle wrote:You need a cert for adjustable suspensions arms unfortunately
Clint
Which also requires cert. Better to get adjustable one certed, then it can be adjusted to suit later on
Us law abiding people would definitely get a cert for such a radical mod but I have heard of some bad bad men who would do something like that, paint it up to look factory & be sure to get it a bit dirty before warrant time
Before indulging in such nefarious activities one should be aware that stock panhard rods can break under extreme 4wd conditions so you'd want to make sure any mods were done properly.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
