thanks for your help
td42 gudgen pin size
y60 safari driver
hi all I have a 89' silver top td42 in a gq and am wondering if anyone can tell me for sure if it will have the 28mm gudgens or the 30mm
Re: td42 gudgen pin size
gudgeon pin hole diameter:
27.992 – 28.000 mm
November 1989 on
27.997 – 28.005 mm
gudgeon pin fit in piston:
- 0.008 - 0.007 mm
November 1989 on -0.003 - 0.012 mm
Gudgeon pin oil clearance in connecting rod 0.025 – 0.045 mm
Piston skirt to cylinder bore clearance:
Factory cylinder liners 0.05 – 0.09 mm
Service cylinder liners 0.09 – 0.13 mm
27.992 – 28.000 mm
November 1989 on
27.997 – 28.005 mm
- 0.008 - 0.007 mm
y60 safari driver
That is awesome thanks. So which ones have the 30mm ones or have I been mislead about that
y60 safari driver
oh cool thank you
