One... when it warms up and if I shut it off.... ( it won't start ) and I have to wait until 20 minutes or until it cools down.. if I put cold water or snow ( as I live in New England ) USA.... it will start up..
The motor is down in power... but when cold runs hard and strong...
Also.... all the vacuum lines that go to the intake... can they be plugged. Can I just connect the vacuum line from the alternator/vacuum directly to the back of the injection pump. The vacuum line that comes off the top of the injection pump to the high altitude compensator .. ( can that just be plugged too).. taking it all out of the loop.. I don't live in the Andes.. ( haha )... or does that have a major to do about giving the little beast power as well..
Would most appreciate anything anyone can do to help me out on this issue..
1: New Head
2: new turbo and waste gate
3: all timing is done on injection and tweaked a tiny bit
4: THANK YOU.....................
