I've been thinking about doing a rear mount setup for a while now due to having the standard front mount continuously block up with mud and being hit by branches
I do however have a ridiculously large amount of free space under the deck and this got me thinking about the possibilities of mounting the radiator flat(ish) underneath the deck.
Some yanks have given it a go over in the States, but I can't find any info on any issues that they ran into. Most people are only focused on the air & water flow through the radiator itself, which isn't a problem.
I was thinking that vibration/knocks would be a big killer over time with flat mounted radiators as the up/down forces from driving offroad would now be acting from the front/rear of the radiator bars potentially causing metal fatigue and cracks. Also, now there will be no convective heat flow in the radiator due to everything being flat, but as long as the coolant flow and air flow is properly maintained, then it shouldn't matter too much.
My thoughts:
- Use a standard aluminium radiator from a Falcon or similar with decent fans and shrouds from the get go.
- Mount radiator flat or at a slight angle to help with bleeding air out.
- Use some sort of spring mounts to reduce vibrations and hard knocks from bouncing when offroad.
- Have a separate filler/expansion tank from the radiator up high to reduce air locks in the system.
- Make a good shroud so that fans pull a decent amount of air upwards through the radiator & have a scoop type arrangement on the lower side to prevent mud & stones hitting the radiator
- Move the water inlet/outlet pipes to the sides of the radiator tanks (instead of the rear) to make water pipework neater and flatter
- Have dedicated air bleed points at the highest part of engine(thermostat housing) & radiator
This is a custom made aluminium radiator with the inlet and outlet ports on the same end of the radiator. A dedicated air bleeding point is on the other end of it.
This is a very rough setup of what I'm thinking to achieve.
A pressurised expansion tank similar to what I was thinking to use. This will be mounted at the highest point in the system.
