Was asked to put a couple pics for Tom so he can see what I did and a very good mate Al did( he designed and got a couple lazer cut for us) We were told by Peter Watson ( LVVTA) that this is a running repair and did NOT need cert. Al has taken his truck through vtnz loads of times and has not been pulled up about it and was told great job..
and
It has a big hole under the SB which is covered but is welded to add strength to the plate as a whole, there are 2 smaller holes which have had the same treatment.. as you can see in the pics..It has been cut out of 2mm mild steel or maybe 2.5,, cant remember
Enjoy
