landcruiser rear wheel bearing tool
Anyone have a rear wheel bearing adjuster tool for landcruisers in chch I could borrow this weekend? have ordered another one from Aust , seem too have misplaced my old one
and only noticed it missing after pulling hubs off yesterday .
Re: landcruiser rear wheel bearing tool
3 screwdrivers does the job sweet mate nip it up tight but don't over-torque it
derk wrote:3 screwdrivers does the job sweet mate nip it up tight but don't over-torque it
Try and stay away from doing it that way these days , same as using a punch on the front lock nuts ....
nah mate it doesn't involve a hammer or butchering anything up
, you stick 2 largish possi drive screwdriver's or similar into 2 of the locating holes on the lock nut and hold both handles together in one hand, you stick the third large screwdriver between the other 2 screwdrivers as a lever and use it to turn them and the lock nut to wind it up nice and snug, only takes 2 seconds and works well
or if you've got a spare hour while the missus is watching shorty st you can knock up a tool out of a bit of scrap lying around the shed you only need an offcut of 6mm steel some thin rod for the pins and an old 1/2 socket to weld onto it to attach your ratchet or torque wrench if you want to torque it to mr toyo's specs
Got a made up one in Hoon Hay.
FITZY. 0274318993
FITZY. 0274318993
SMOKEY wrote:Got a made up one in Hoon Hay.
FITZY. 0274318993
Thanks , borrowed one from old work mate who's a Toyota nut . job done before he even finished the stubbie of beer I gave him
Changed all the fluids , bleed the brakes and probably went past your place on a test run up to the kiwi this evening .
Good to have the old girl out of the garage , WOF sat and back out earning it's keep spotlighting sat nite
