Prado 1KZ into 04 Hilux
u13turbo
Post by u13turbo »
Doing an ecumenical replacement on an 04 1kz hilyx. Found a Prado 1kz engine for a good price and just wondering if anyone has tried this? How much needs to be swapped over? Sump, manis, injector pump?
KIWI_TERRANO
Re: Prado 1KZ into 04 Hilux
Post by KIWI_TERRANO »
What motor is in hilux at moe?
u13turbo
Post by u13turbo »
1kz. Same motor but think they swaps bits and peices
KIWI_TERRANO
So you want to swap from a 1kz non intercooled to a intercooled?
Why not swap interooler and inlet manifold and vlve cover onto your current motor to save you alot of work?
Motor will swap over tho if you want to do straight swap
KIWI_TERRANO
04 hilux has a fly by wire throttle and prado is cable so there alot to change over...
u13turbo
Post by u13turbo »
Yeah I'm not to worried bout manifolds and that its the sump I don't want to swap
KIWI_TERRANO
Yer but im saying just swap the intercooler, manifold and valve cover instead of doing motor swap cause it will be a hell of alot more work...
If your doing motor swap better swapping sump think prado one different
