Looking at putting a KZN130 on 33" tyres with 15 x 10 wheels. Just wondering If i have to do both a 2"body and 2" spring lift. Or would I be able to quite comfortably get away with a 2" spring lift and a 1" body lift or a 1.5" body lift.
Cheers guys.
KZN130 bodylift for 33" tyres
Re: KZN130 bodylift for 33" tyres
I've had 33" simexs (on 15x8s though) on a VZN130 (same but V6) with 2" suspension and 1" body lifts. just watch the offset on the rims. and use a big hammer on the seam on the body behind front wheels, bend it over and flat.
Andrew 0272226292.
Andrew 0272226292.
Will 15x10 with -44 offset clear??
Put them on 8 inch rims ... will stay on much better at low pressures and will also be taller.
