Started the weekend by fitting a new Mudstuck 9,500 winch to my hilux.
In answer to the questions I had before fitting the winch
1. Yes a 9,500lb electric winch can be installed into a MCC winch bar on LN106 hilux without removing the bar, it's a one man job even.
2. No there is no where to mount the solenoid box out of harms way, it is cabled tied on top of the winch bar for now.
I will get some longer leads next week and mount the solenoid box under the bonnet, with a battery master switch on the positive lead so I can leave the winch turned off, might even add in cab controls as well.
8th and 9th August 2015
Re: 8th and 9th August 2015
nzlux wrote:I will get some longer leads next week and mount the solenoid box under the bonnet, with a battery master switch on the positive lead so I can leave the winch turned off, might even add in cab controls as well.
try use the biggest mm2 cable you can find to keep the resistance down the cables they supply with most of those entry level winches is low gauge and tends to get a bit warm and droopy its not good for the performance and longevity of the winch motor when thing's are operating under those conditions
derk wrote:
try use the biggest mm2 cable you can find to keep the resistance down the cables they supply with most of those entry level winches is low gauge and tends to get a bit warm and droopy its not good for the performance and longevity of the winch motor when thing's are operating under those conditionsand try and get a high amp rated good quality isolation switch like BEP or Hella that can cope with the high CCA winching load rather than a budget one that's another place you can end up with resistance in the circuit, after throwing the money at the bar and winch you might as well finish the job off properly
Will do thanks for the tips
