I've had a quick assessment today and dont know whether to tackle it myself or drop it into an auto sparky?
The trucks a 70 series cruiser with a twin battery setup, the batteries were proffesionaly installed 4 years ago by the previous owner and have a relay between them, the winch battery is dead flat (ie: 0 volts) and the other battery is fine (I used the winch 4 weeks ago and it functioned ok). I've removed the winch battery and the other battery has about 12.5 volts idle and 14.5v with the engine running so it looks like its charging.
When I put the meter accross the fuse box I only get 10v and when I turn on the lights/wipers etc it drops down to around 2.5v, when I do this and measure accross the battery the voltage remains at around the 12v mark. I thought the problem may be the feed to the fuse box but the solinoid on the starter/ignition must run through and works fine while the wipers come to a stop, air horn wont work and headlight relay chatters?
anyone out there got any ideas
