Kzn165 egr removal
Jared245
Newbie
Newbie
Kzn165 egr removal
Post by Jared245 »
Hi I have completely removed my egr from my kzn165 Hilux now have a fault code coming up caws the plugs are no longer connected to the egr valve thing is there anyway to get around this cheers
kbushnz
Re: Kzn165 egr removal
Post by kbushnz »
Plug the valves back in, but don't connect the vac lines.... The ECU in some toyota's like "see" the little solenoid valves.
floatingkiwi
Post by floatingkiwi »
Put a ball bearing in the vac line between the little filter thingee and the egr sensor plug.
1999 KZN185W SSRG TJM T-15 Bar, Tigerz11 2speed winch, 2" EFS sus lift, 265-75R16 Engine guardian. Auberins EGT. LED light strips. weathertech cargo liner. Safari Snorkle SS145HF. Prado rad. Front and rear E-locker.
