just the other day I noticed this novelty in my 1994 Nissan Homy, TD27 - when starting up the car, as soon as I turn the key into warming up position (all lights come on, glowplugs warming up) there's an abhorrent noise filling the cabin which took me some time to locate.
I first thought it might come from the stereo which it didn't. After a series of startups I discovered a little 12v horn under the dashboard on the driver's side next to the door.
It starts to give a signal as soon as I switch the key over to ignition (not starting the engine) and holds it for about 20 seconds or until you start the engine and then slowly gives out. I haven't noticed it before and it came on for the first time after I changed my waterpump, radiator and thermostat. Did I put an earth wire in the wrong spot? I'm wondering what it is trying to tell me?! Low oil, low diesel, low whatnot? Overcharged battery? Wires are coming from the same harness as the purple connector.
I didn't find a wiring diagram or anything similar on the webs so just hoping to find some help here.
