G16a camshaft grind
For all Suzuki related topics
drewz1
G16a camshaft grind
Post by drewz1 »
Has anyone had there camshaft grind done by auckland camshafts?? What benefits did you get i am thinking about doing it but wanted to see what others thought first
deadduck
Re: G16a camshaft grind
Post by deadduck »
Do it real good mod get a stage 1 nice low down and mid torqure
If you don't succeed. Try again with "more revs".
https://youtu.be/d9o8YZLmOPs?t=1m34s
Filthy4x4
Post by Filthy4x4 »
Yeah do it. Henry knows what he is doing. He runs one in his zuk and it goes well.
027 MUD GEAR - (027 683 4327)
Check our facebook:
drewz1
Post by drewz1 »
Awesome thanks will it affect fuel economy at all??
Sausager
Post by Sausager »
What's a cam worth?
You Get That
Post by You Get That »
These for carb or injected -g16
Addicted to suzukis....
Mazuki
Post by Mazuki »
I'd be interested to know the price of a cam grind. The scudo lacks a bit of power running 31s
BMC
Post by BMC »
x2 I'm on 30's and would also be nice to have some low down tourqe.
In saying that Suzukis are made to rev......., possibly it would not achieve much without supporting exhaust system and headers.
Mazuki
Post by Mazuki »
all cam specs and pricing is listed on their web site
http://www.aucklandcams.co.nz/cam_listi ... ?title=all
$165 is pretty good I recon bang for buck wise.
drewz1
Post by drewz1 »
does anyone know if I can get the cam out of a 8 valve g16a with out taking the head off so I can get this cam done??
Mazuki
Post by Mazuki »
Yup Easy pessy. I think the cam may even have to come out first anyway as it is positioned over the head bolts ? Either way head removal is not required.
drewz1
Post by drewz1 »
Awesome thanks heaps for that
Mazuki
Post by Mazuki »
Hi drewz1
After doing a bit of research it seems the head does have to come off for the 8valve. Sorry to put you wrong , my experience is only with 16 valve motors and I mistakenly thought they both would be the same. :oops:
You Get That
Anyone know if the 16v cams would work in a 8v?
derk
Post by derk »
You Get That wrote:Anyone know if the 16v cams would work in a 8v?
16v = 16 valves and 16 cam lobes
8v = 8 valves and 8 cam lobes
Return to “Suzuki”
