proportioning valve kzn130 surf
phatlaurel
Post by phatlaurel »
ok so ive searched the forums for ages and cant find the answer...... do I need to mess with the proportioning valve on the rear diff of my surf when I install my 2" suspension lift????? if I do, then how/ what do I do
mudsurfv6
Re: proportioning valve kzn130 surf
Post by mudsurfv6 »
just unbolt off diff bracket and bolt a flat piece of steel into those holes on diff bracket, to make a new bracket, and bolt valve onto new steel bracket 2 inches higher than factory.
Andrew 0272226292.
phatlaurel
thanks that sounds easy enough
phatlaurel
mudsurfv6 wrote:just unbolt off diff bracket and bolt a flat piece of steel into those holes on diff bracket, to make a new bracket, and bolt valve onto new steel bracket 2 inches higher than factory.
does it cause problems if not done ie brake failure?
mudsurfv6
Post by mudsurfv6 »
won't cause brake 'failure'. rear brakes just won't work or will hardly work, depending on how much weight you have in the back. its designed to put more braking to the rear the more weight you put in the back. so by lifting chassis 2" away from diff that changes the angle of valve, it is saying you have no weight in the rear of vehicle.
you won't get a wof without lifting diff bracket. I've tried. :roll: . unless you lower the chassis end by 2", but that's not as easy.
Andrew 0272226292.
phatlaurel
thanks that's helpful.. guess ill get onto making a bracket. wof time in 2 months
phatlaurel
mudsurfv6 wrote:won't cause brake 'failure'. rear brakes just won't work or will hardly work, depending on how much weight you have in the back. its designed to put more braking to the rear the more weight you put in the back. so by lifting chassis 2" away from diff that changes the angle of valve, it is saying you have no weight in the rear of vehicle.
do you have a pic of your bracket handy?
mudsurfv6
Post by mudsurfv6 »
no wasn't really into recording everything then, been a few years since I've played with 130s.
just use a piece of flat steel 30mm roughly wide or whatever you have lying around. about 100mm long or so, enough to lift the holes up 50mm.
drill 2 holes in steel to bolt onto bracket on diff, then measure 2 holes 50mm above for the valve to attach to. \
like this.
Andrew 0272226292.
