Trying to get together all the bits and pieces to put a turbo back on the LD28 in the 110
I all ready have a L20ET manifold and L20ET turbo on the way . I was going to use a R50 Terrano QD32 turbo but discovered after buying one that the inlet flange is T25 and does not match up to the L20ET T3 flange doh !
Anyways , how have people plumbed up the oil feed and return line on their LD28 turbos ?
It look like I could T off the vacuum pump feed and return but I'm concerned about pressure to the turbo and volume restriction on the return .
The other option is to T out of the oil pressure sender port and route around the back of the block to the turbo . And pull the sump and fit another return port for the turbo oil.
So can any one tell me what thread the oil sender uses ? 1/8th BSP or NTP?
And what thread the vaccum pump feed on the block is ? Looks like M12 fine but not sure.
I know I need to reroute the PCV to the intake side of the turbo and from what I've read the fuel pump dosent need to be touched . But is there anything else I'm forgetting ? Exhaust dump /pluming is all in place all ready and intake plumbing easy enough to sort out . Also plan to tap the exhaust mani pre turbo for a EGT probe .
Cheers Chris
LD28 Turbo setup
LD28 Turbo setup
LR110 ..... LJ50 project
Re: LD28 Turbo setup
yeah you want the return to go into the sump. Fairly high towards the block from memory( I had a ld28 turbo in my former 110 )
Pretty sure my oil feed teed into the oil pressure sensor, rather than run a pipe behind the block, it went straight over the rocker cover to the top of the turbo. The pipe was a small diameter plastic pipe, similar to airlines in a truck.
Pretty sure turbos don't need much flow and pressure, from memory they usually get a restrictor in the inlet side, and a nice free drain back to the sump.
To much oil and pressure causes foaming and bearing failure or something from my vague memory when I was snailing my Safari way back when............
The LD28 in that Series IIA we had was a JDM factory turbo, this is how the oil supply was set up from the factory. The line going around the back of the block was metal (copper?) from memoryThe other option is to T out of the oil pressure sender port and route around the back of the block to the turbo . And pull the sump and fit another return port for the turbo oil.
I would prefer it around the back of the block so it doesn't need to be disconnected to get at the tappets . I also don't like the potienail for an air lock in the line with an up and over setup.BlakeNZ wrote: rather than run a pipe behind the block, it went straight over the rocker cover to the top of the turbo.
From what I've read , ball bearing turbos need a restricted oil flow and standard metal bearings don't need the restrictor .DieselBoy wrote:Pretty sure turbos don't need much flow and pressure, from memory they usually get a restrictor in the inlet side
Sounds like this is the method to use them. Do you remember how the oil drian was setup? Did it share the vaccum pump drian port.lax2wlg wrote:The LD28 in that Series IIA we had was a JDM factory turbo, this is how the oil supply was set up from the factory. The line going around the back of the block was metal (copper?) from memory
Looks like the Turbo LD28 had a higher pressure oil pump too . Might give the relief spring a tweek .
Sorry I don't remember exactly... but I want to say that it had a separate drain port on the sump.UBZ wrote: Do you remember how the oil drian was setup? Did it share the vaccum pump drian port.
