At the present point, my truck is a 3wd, the other hub wont engage, took it to bits to see if there was water in it the other day and since putting it back together it hasnt worked. See that there are slotted bits on the cog looking thing which gets pressed onto the axle, aswell as a flat spot where some of the lil lips are not, just wondering is that side ment to be on the innerside of the truck or outter, also all the outter teeth marks, get slotted in what place,
Well hope that kinda makes sense,
kaney if you can add anything to describe it better ???
asin hubs problem
with the clutch engaged it spins the inner hub but the drive shaft doesnt turn, realigned the springs (where way out
) put back in but seemed to be no go, even just put the clutch part in so it was engaged between the inner hub and the outter hub but somthing aint workin as the inner hub is turning and the outter but nothing on the front drive shaft, or am i still doing something wrong
