URGENT HELP - NORTH SHORE
HELP
Does anyone on the north shore have an 80 series cruiser rear driveshaft uj or know where one can be found ASAP ??
Sig is stranded up that way having a fairly shitty holiday so far and needs help.
He cant log in to ORE so if you can help then contact him on his cell.....
021724482
Cheers guys
sig
Jeep Jeep
Re: URGENT HELP - NORTH SHORE
Post by sig »
right have managed to find my password and log in .am still diagnosing but rear driveshaft appears fine .am getting vibration from front so tomorrow will reinstall rear driveshaft and remove front and try that.dont you just love holidays when all you do is fix your own
bloody 4x4s in any town but your home town
mudy1
Post by mudy1 »
hi there if you need some parts form well and can have them to me by Tuesday lunch time I can get them up to you as I am laveing well for Auckland so can bring them up ,,,, trevor 0210595548
sig
Jeep Jeep
Post by sig »
its looking more like the replacement spindle i put on a couple of days ago may have been a bit worn and the brass bush may be spinning with the cv causing the vibration thru the front end.am going to remove front driveshaft and driving plates and try that this morning
Lchundy
Post by Lchundy »
My 80 done that after I put new cvs and brass spindle bushes in
Bad sounding rumble/grinding when not under load
Replaced brass spindle bushes with bearings then sorted
I've still got the old drive plates with brass bushes if there any help
sig
Jeep Jeep
Post by sig »
after taking driveshaft and front driving plates off vibration is gone.lots of movement in cv so pretty sure brass bush has picked up on new cv and munted itself .all good now.quite interested how it will be in 2wd as a part time kit was on my shopping list this year.thanks for all texts and calls to help.once again the wide world of ORE has a wealth of knowledge and help
Return to “Tool Shed”
