Hi all,
I have recently swapped a 3.9 and auto into my 110 land Rover. Given that it had the Lt77 attached to a ld28 the rear driveshaft was too short with the new combo (front is standard disco item). I am now looking for a reasonably priced engineering shop in Auckland to rebuild the shaft.
In an effort to get it moving I made one the correct length out of a disco and my 110 item but given that it was a temporary one made on the floor it is not completely straight.
Can anyone recommend someone reasonably priced to either cut and straighten my shaft or retube the whole thing?
Driveshaft shop in Auckland?
- mudlva
Re: Driveshaft shop in Auckland?
Drive shaft specialist
Russell
092731532
32 Andromeda Cres
East Tamaki
Auckland
New Zealand
Been doing my d.s. for years good job and good prices compaired to betties
Russell
092731532
32 Andromeda Cres
East Tamaki
Auckland
New Zealand
Awesome cheers will give him a bell!
I've had a few shafts made for the Sals to disco axle swap at ATL in Hamilton if that's any help
http://www.atlbalancing.co.nz
you sure there isn't a factory length? Let me know and I will go through the shelf. you wouldn't of had the measurement the other day!
Cheers man, Ill give them a bell as wellDieselBoy wrote:I've had a few shafts made for the Sals to disco axle swap at ATL in Hamilton if that's any help![]()
Yep LT85 110 should have the correct shaft. Will flick you a messagelilpigzuk wrote:you sure there isn't a factory length? Let me know and I will go through the shelf. you wouldn't of had the measurement the other day!
