So who's the man that knows his shit on the td27eti or qd32?
R50 96 td27eti auto 4x4
Nissan 14pin.
Got fault codes 11 & 47
11 crank angle sensor.
47 TDC sensor. Crank sensor
Picking they are the same sensor. On front of engine just above crank pully.
Had #47 1st truck was running and light came on and went off and came back on and went off.
Then had #11 when trying to start, would not start. After a lot of attempts to start I tried, foot hard up it a few cranks and it started.
So picking it codes 47 when engine is running and 11 with it won't start ???
Crank sensor faults r50
Re: Crank sensor faults r50
three sensors at work there, which tells me you have a wiring issue, if it was a sensor you'd only get one code
no1 lift sensor (which provides the TDC pulse signal)
cam angle sensor ( its nowhere near the crank shaft)
and the injection timing control valve (which is on the pump and why it has trouble starting
take it to a sparky and get a Consult II plugged into it and it will tell what it is causing the trouble.
common faults.
5 volt ecu circut fails
TPS fails
injection timing control or also know as the COMMS line to the eti pump fails
common faults.
TPS fails
